Results 14 to 20 of 20
    Not saying its right or wrong but for a typical system this thing was designed for you will not get that run time at those speeds.
    That thing would clear a resi system shortly after it was turned on
    Would like to see it like we would use it not some set up to fail rig.
    Mar 2006
    Lancaster, PA
    Quote Originally Posted by eurocool View Post
    Here are 3 new videos showing the TR21 in operation.
    http://www.youtube.com/watch?v=aqArRG8WkYY
    That's got to be the worst set-up for a practical test I've ever seen. Of course converting all those watts to heat energy by compression in a closed loop is going to create super high temperatures. Air is not going to condense.
    Just wasted 15 minutes of my time watching that.
    keep your ice cold and flame hot
    Jun 2002
    Dacula, GA
    Just got a report from a friend in Florida who said he reclaimed 125 lbs in a recovery tank in 30 minutes from a couple of chillers using the MT69. Might be something to that. Thank you very much
    Sen. Barry Goldwater
    You can use the MT69 with any recovery unit. Does he have the TR21 also?
    Aug 2009
    Peoria IL
    can anyone watch the videos they come up private when i try view the link
    Nope they are private now.
    If I remember right the guy showed how hot the pump got and also fried an egg on it.
    Jun 2002
    Dacula, GA
    An update on the MT69. This unit has about 20' of 3/8" copper tubing coiled in a metal case. You set this in a bucket of cold water and your in business. Cools off the refrigerant and goes into your reclaim tank fast with a lot lower pressure. Thank you very much
    http://www.centurytool.net/MT69_CPS_..._p/cpsmt69.htm
