Results 1 to 8 of 8
Thread: Help with Coleman HP
02-04-2012, 12:08 AM #1
New Guest
- Feb 2012
- 5
We got a 14seer Coleman Echelon in 2007 and it has worked pretty well. All of the sudden if I try to run the AC the outdoor unit turns on for about 1-2 min and shuts off.
I cleaned the outside coils today and noticed a fault light for a low pressure lock out.
What does that mean.
Could I have set something improperly in my tstat?
Heat and Em heat work fine.
Thanks for all help.
02-04-2012, 12:11 AM #2
Is it cold out?
Best to call your HVAC company.Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
02-04-2012, 12:20 AM #3
New Guest
- Feb 2012
- 5
It has been between 50 and 80.
The past month it has gotten into the 20-30 range.
02-04-2012, 12:26 AM #4
New Guest
- Feb 2012
- 5
FYI
Its a Coleman HC5B036F1B with a Climatouch CT03ts32H tstat. I can get the info on the attic unit
02-04-2012, 12:28 AM #5
I meant was it cold out when you turned on the cooling.
Sounds like you may have a leak in the system. You really do need someone who knows what they are doing check it out. If the system is shutting down on low pressure issues, something is wrong that needs to be fixed or it is going to get much worse.Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
02-04-2012, 12:32 AM #6
New Guest
- Feb 2012
- 5
Thats what I was told I just wanted to make sure before the repair guy could pull one over on me. I just was shocked that a 5yr old unit could have a leak.
Are there any other things that could cause this issue?
Thanks!
02-04-2012, 07:25 AM #7
Professional Member*
- Feb 2006
- Float'N Vally, MS
- 1,608
02-04-2012, 04:35 PM #8Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
