Results 1 to 13 of 18
    I am a student in HVAC/R and we are starting A/C Refrigeration Tomorrow and our teacher asked us to list the steps for Pumping Down???
    All Help Is Greatly Appreciated!
    Washington
    First thing you should do is perform a search on this site: vacuum, pump, ac charging.
    I can tell you that the first step in pumping down is pressurizing with nitrogen. Good luck
    My impression of the question, seaton, is that he is asking how to isolate the refrigerant charge into the reciever or condenser.
    You have to give us more to go on 86.
    Memphis
    Here's how we do it. We let the a/c run for a few minutes. Put your gauges on (of course). Then close the liquid line valve with a valve wrench. You'll see the pressures start to go down. We usually wait til the suction pressure gets to about 15-20 & pull the disconnect. The valve in the compressor will shut off the other side. After this, close the suction line valve & recover the rest. There will be very little to recover.
    You can let your suction pressure go all the way down to zero, but its not real good for the compressor.
    Life is like a jar of jalapenos. What you do today might burn your ass tomorrow.
    Washington
    Is that something they teach in classes though? I always figured that was just something we do in the field to conserve refrigerant. I highly doubt they would teach that in school considering the strain it puts on the compressor. I believe he is asking about evacuating. Like bennie said, more info please.
    Nov 2005
    netherlands\europe
    Could it be that you mean, a pump down after a cooling cycle?
    This is how it goes at the end of a cooling cycle:
    The unit drops the liquid valve, the liquid gets stored in the liq, tank, the unit pulls a low pressure becouse there is no more gas to move[ the liq, valve holds the liq,], the pump-down-pressostat stops the compressor.
    The next time the unit has to cool again, it can start with less starting amps.That is a plus!!and much easyer for the compressor.
    ---------Holland aint flat !!! it is hollow !----------- first thing my mommy told me was : learn to swim
    Yes, exactly. This (what dutchcool just described) is a "pump down system". It is common to see this type of system on walk-in coolers.
    Florida
    So the first thing your teacher asked you to learn/list is pumping down a system? Sorry, I don't believe you. Register as a pro if you're really a student.
    You're a DIY IMO.
    [Edited by smokin68 on 04-11-2006 at 05:39 PM]
    Nov 2000
    Coastal Georgia
    eh?
    Florida
    How about semi-pro James? There's already some in there.
    Nov 2000
    Coastal Georgia
    You do know that once upon a time there was a student. Maybe we need a student section or wait a while before he rip their heads off. I would rather piss on a electric fence than to cut a young kid up trying to learn this trade but just the same I don't think the pro area should be a open to students. That is why it is called the "Pro" area.
    Florida
    I wouldn't purposely rip any student/person trying to learn the trade.I love learning myself. However,due to the Forum in which this was posted, I couldn't answer him/her even if their legit. I looked up their past posts, and just doesn't look right....sort of DIY topics. A student section would be DIY in no time IMO.
    Feb 2005
    GEORGIA
    AMEN..
    "Value our Differences"
