Thread: one cold room
    Nov 2010
    indiana
    one cold room
    The cold room is farthest from the furnace. All ductwork is in a crawl space which is not insulated but not cold. The cold room shares a return with the adjoining room. There is a 3/4 inch gap under the door which allows some air to return to the common areas of the house. Would a constantly running fan help? Is there a good strategy to moderating the heat in the house/ improving the airflow to/from this room?
    Running the fan will help, but can't sy how much. Not enough info about the room or duct system.
    Massachusetts
    Any reputable company that does duct installations should be able to help out. You'll know if they're reputable if the insist on doing a full room-by-room load analysis before they'll touch the duct system. A good tech can just look at the ducts and often see issues. But that does not give him/her the total picture. So...start with the phone call and the appropriate question, "How do you size ductwork?" If they don't say something to the affect of "By doing a load analysis", or "By Manual 'D'" then keep looking. It'll probably take a bunch of calls before you find the right company. But when you do, please mark their number in your favorites notebook for reference now and forever, as you've found a winner and while costing more, their worth their weight in comfort.
    Fort Worth, TX
    Does the room stay warmer if the door is left open?
    If not, it's not likely starved for return air. It's starved for SUPPLY air.
    Building Physics Rule #2:
    Building Physics Rule #3:
