Results 1 to 8 of 8
    Nov 2009
    West Monroe, LA
    Insider Mobile home unit???
    I am looking at a 97 Model trailer with a Insider system. Is this a self contained inside unit? I can't find a a/c condenser outside and the guy sailing it said that the compressor was inside? Can parts still be found for this in case I have to repair anything? The system info. Listed below
    Model#. CDHP36A100B
    Serial# 95060143
    It ended up in the Carrier family, might be a source of parts.
    Jun 2011
    Central Indiana
    Friedrich is who you would have to call for parts. And yes they will be expensive.
    The only true knowledge is the pursuit of knowledge
    junebug1066,
    Nov 2009
    West Monroe, LA
    So is it a self contained inside heat pump with no outdoor unit? Also I am assuming if need to replace would choose too put down flow air handler in & place outdoor heat pump?
    Jun 2011
    Central Indiana
    Yes it is a self contained unit. Think of it as a package unit just inside the house. Hence the name. Friedrich makes a replacement self contained indoor unit but if you want to do the next guy a favor put in an air handler and a heat pump
    south louisiana
    I learn something every day...
    never heard of Insider.
    does it work Adam?
    ducts in floors?
    what type of insulation in floors
    (usually blown fg with 'belly' covering)
    They aren't unusual. Like a Magic Pak or commonly known today as a V-tak. They've been around since the 60s. Fedders made them that long ago.
    Friedrich, GE Zoneline, Skymark, Magic Pak, they are still out there.
