Thread: AC line routing
    Jan 2012
    Denver
    AC line routing
    I'm researching replacing my 33 year old A/C, and would like the new line set routed differently.
    It currently takes an almost level (evaporator inlet on air handler is approximately 1 foot below the condenser's connections) but circuitous route (multiple elbows).
    If the new line was routed as shown in the attached picture, it would have a roughly 3 foot-high arch near the air handler. Would this be a problem?
    Thanks.
    - Bill
    Portland OR
    Shouldn't be an issue, most units can work with up to 100 feet of line set and 20+ feet of rise at a minimum so you should be fine. But only a pro after seeing you home and circumstances can verify that.
    Check out my YouTube channel - http://www.youtube.com/user/skyheating1 We have customer testimonials, product reviews and more!
    Like us on FACEBOOK if you like our advice here!
    Quote Originally Posted by wwh View Post
    Thanks.
    - Bill
    There is nothing wrong or unusual provided the proper tubing dimension is used.
