Results 1 to 13 of 31
    Mar 2006
    Single gauges for hooked to a critically charged system
    Ive seen them but cant remember where. Used to checked the pressure on a system that hold a few ounces of gas. some pics would be nice too
    They told me to use the brain God gave me.
    I did.
    Now I'm an Atheist. Ironic, isn't it?
    Nov 2001
    east kansas
    Regular guage and a fitting from most supply houses.
    Beware of advice given by some guy on the Internet.
    Jan 2006
    S. Texas
    We used to crimp the process/charging tube and braze it shut if it was that close.
    I also had a tool for GE systems you screwed onto a special fitting that allowed you to close the fitting off before removing the hoses- got stolen- will never find another one. Dates back to the 40's-60's anyway and not used anymore I think.
    Using ball valves or placing a new rubber seal in the hose end where it closes the valve core before the seal breaks is another way.
    Haven't done much of it lately (years)- perhaps there is a better way.
    Mar 2006
    what about those single digital gauges ?
    http://yellowjacket.com/product/853
    does anyone else make something like this.
    mostly going to be use for small 404a/134a units. I like the accuracy
    I did.
    Mar 2006
    New Zealand
    Who's going to be first to remote the transducers from a Digi-cool instrument. Would be real easy to do. a,la Robinair and Cooper.
    Mar 2006
    Quote Originally Posted by kiwireeferman View Post
    thats what im wanting. i get the precision of a digi. but without the lose of gas on a 12oz system
    I did.
    Jul 2009
    Columbia, MD
    ball valves. i close both sides unhook very quickly and attach liquid hose to vapor line and let it dump back into the unit. i love doing it this way.
    Quote Originally Posted by gravity View Post
    On a critical charge unit, this is a big mistake.
    Once you've trimmed the charge to where it needs to be, pull the hoses off and walk away!
    If you put that high side liquid in, you just over charged the unit.
    Apr 2010
    Ontario
    Would you consider installing good quality permanent gauges.
    ENJOY THE RIDE
    Mar 2006
    New Zealand
    I believe you need to qualify that statement.
    Critical charge to me means manufacturer has stated the volume of refrigerant the system should contain.
    If the charge has been weighed, or put in with a charging cylinder how can it be overcharged by bleeding the high side hose contents to the low side.
    You weighed in the exact charge, accounting for the volume of refrigerant contained in the hoses.
    You have also verified that the auperheat and subcooling are correct.
    Now, you're going to add a couple of extra ounces of refrigerant by emptying the hoses back into the unit?
    Yep, that's an overcharge.
    Mar 2006
    New Zealand
    Don't think so. The system calls for a 30oz charge. You charge till the scale shows 30oz has left the can. You turn off the valve on the can.
    Where did this magical 2oz come from.
    You are not measuring what has gone in, you are measuring what has left the jug.
    I don't believe you can use a scale to weigh very small volumes anyway.
    Hoses only need to move slightly and your up or down a 20-30 grams.
