Results 1 to 10 of 10
    Jan 2012
    York,PA.
    What Am I Missing?
    Two Luxaire Furnaces- Model #PBFMD12F08501A and Model#PBFMD12F05501A.Both Furnaces Use The Same Blower Motor And Wheel With Different Airflow Ratings.Something Has To Regulating Flow On The Smaller Output Furnace.
    Jan 2012
    York,PA.
    No,All unit dimensions,filter & duct openings are identical.It almost has to be electrical.
    Jan 2012
    York,PA.
    Quote Originally Posted by Jeff P View Post
    Here is wiring diagram:
    Charleston, SC
    Smaller furnace has higher pressure drop across furnace section?
    "Customer Service" is not a department, it's an attitude!
    S.E. Pa
    Bigwave, This is the Ask Our Pro's or AOP forum. In order to post responses here, you must have verified qualifications and have been approved by the AOP Committee. Please see my signature line for links to register and review the AOP Forum Rules. Thank you. Your post will now be deleted. Further infractions may result in loss of posting privileges.
    Lancaster PA
    Probably has baffles in the smaller one to make sure air flow goes over the heat exchanger. And not bypass it.
    Jan 2012
    York,PA.
    Thanks beenthere.I have seen low firing rate baffles mentioned after searching it.This is the only PDF I have found:http://www.hamiltonhomeproducts.com/...s/Pfm-tech.pdf
    Jun 2010
    Philadelphia PA
    2 different airflows
    means 2 different pressures with this twinned unit SO the unit with the higher pressure is stopping the air delivery from the smaller unit. Not good since winter operations could see high limit trips and cooling will have frozen coils.
    The units need to be balanced airflow regardless of dischagre temp. The air will mix so no need to worry.
    Jan 2012
    York,PA.
    I take it this is a bad design.Adding baffles to reduce airflow to save manufacturing costs.I am looking into natural gas.(line is appx.350' away) and hopefully get rid this fuel hog furnace.
    burlington county n.j.
    if the cabinets are the same size it would make sense to have baffles and a smaller heat exchanger.
