Results 1 to 13 of 13
01-27-2012, 04:17 PM #1
- Mar 2009
- 214
Anybody use these isolators on a trane condensing unit?
I am looking to cut down the noise that is being transferred through my walls.
http://dar.proflo.com/darmanager/Que...E=INSTALLATION
01-27-2012, 06:42 PM #2
Since you're asking this question in the middle of winter, are you speaking of a pure cooling system or a heat pump that both heats and cools? If the former, then yes, we use them all the time as they're shipped with the units in a plastic bag. If the latter, the unit should be elevated on pump-ups so the HP can drain during defrost cycles and in that instance we do not use isolators.
01-27-2012, 07:13 PM #3
Professional Member*
- Dec 2011
- PA
- 98
01-27-2012, 08:23 PM #4
- Mar 2009
- 214
It is a heat pump. Here is a picture. How can I tell if it is on pump-ups?
01-27-2012, 08:29 PM #5
Its not.
Make your expertise uniquely valuable.
Make your influence uniquely far-reaching.
01-27-2012, 08:33 PM #6
Here is some info for you.
01-27-2012, 08:39 PM #7
- Mar 2009
- 214
Do you have a pic of pump ups and can you tell me what they are? Will they help the resonance issue that I am having?
01-27-2012, 08:42 PM #8
01-27-2012, 08:44 PM #9
Sorry , can't help with that as there not used in my world " Arizona".
01-27-2012, 08:45 PM #10
- Mar 2009
- 214
I found a pic of the pump-ups. I would say less than 1 out of every 10 in my complex has those. Most of them are just mounted on a pad directly on the ground. They are not even elevated on blocks like mine.
Do the Trane HPs require pump-ups and will the rubber isolators be enough instead?
01-27-2012, 08:52 PM #11Make your expertise uniquely valuable.
01-27-2012, 10:21 PM #12
- Mar 2009
- 214
Does anybody have a pic of a trane unit with the BAYISLT101 kit installed?
01-28-2012, 08:23 PM #13
- Mar 2009
- 214
jimj, according to that PDF of the Trane Tracks news letter, there were 3 parts to the series and one part was structureborne, which you posted, and one was airborne. Do you have the "airborne sound transfer" edition of that news letter?
