Results 1 to 13 of 14
    Sep 2011
    tampa, fl
    How many manifold Gauge sets?
    one of my instructors mentioned that he has different sets of gauges for the different refrigerants due to the different oils and not wanting to cross contaminate , which I understand the concept and theory behind that, but I was wondering of there was a different way, such as cleaning my hoses out or just using different hoses for each type of oil, because I just bought a digi-cool and I want to make sure I do things properly in the field , but not have 5 sets of digi-cools
    Oct 2011
    Chicagoland Area
    If you're worried about cross contamination, why not use 1 manifold and multiple sets of hoses. Personally I have 4 sets. One with 3ft valved hoses for self contained equiptment, two with 5 or 6ft hoses for rtu's and one for units I know have dye in them. Will be purchasing another set since 410a is becoming more prevalent in commercial equiptment.
    it's hype, if you are getting enough oil in the hoses to be concerned, you've got bigger problems to worry about
    4 digital sets & at least that many analog sets; i waste a lot of money on tools
    Dec 2010
    New Orleans
    two does it for me, but I try to stick with ac stuff, unless it's a big refer or something I'm not crazy about working on little stuff that requires all different coolants.
    Two standard plain jane Yellow Jacket gauge manifold sets with 6' heavy duty hoses on both of them. One for R-22, the other one for R-410a. I have 3 sets of Yellow Jacket quickie gauges for R-22, R-410a, and R-134a. I use the quickie gauges for practically everything. I can't even remember the last time I took one of the manifold sets out of the van, even. I am not building spaceships, and I carry a PT chart with me everywhere, so the old-school analog stuff works great for me.
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
    Sep 2011
    tampa, fl
    thanks for the input, since i'm just starting out, when i heard that i was like what the heck, I just paid a bit for the digi cools and now i have to get other ones.
    [/QUOTE]
    4 digital sets & at least that many analog sets; i waste a lot of money on tools[/QUOTE]
    I love to buy tools, so im sure as i get more experience i will have many sets but for now.......
    Mount Airy, MD
    Quote Originally Posted by Tech Rob View Post
    State College, PA
    I am no alone now ...
    Glad to see I am not the only one that likes the basic YJ manifold. I have the heavy duty hoses and change the gaskets often.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
    Myrtle Beach, SC
    I have the Digi-Cools. One set. And one old Yellow Jacket analog for backup.
    I got digital gauges when I started seeing how bad the accuracy was on analog sets. We had one tech that hooked up to a 410a system while purging lines. The liquid line was soldered to the suction line in the attic. The hi & lo side gauges read 50 psi different. With charging so critical, I decided to get gauges I could trust.
    Remember, Air Conditioning begins with AIR.
    Sep 2011
    tampa, fl
    I just got my digi-cools in the mail and i have to say they are awesome, now i just have to upgrade my hoses, have some cheap ones off e-bay and are they ever cheap,
    Thank you every one for the replies, I'm grateful for all the input from everyone in the field
    Cincinnati, Oh
    I keep 3 sets.
    One for checking refrigerant levels for your average deal. standard YJ
    One for pumping down systems. Titan II, with the 3/8 hose.
    One for recovery, or for a system that I know is contaminated.
    "Just get it done son."
    Dad adjusted
    Virginia
    I have 3 1 for 410 1 for r22 and 1 I use to recover and pressure test with.i am going to get me a set of fieldpiece digitals when things pick up in the spring
    Athens, Ohio
    I have 3 sets - Digicool 9000, Fieldpiece SMAN3 (I haven't decided which one I like best) & analog (just as a backup).
    As for oil cross contamination, I agree with 2sac - if there's that much oil in the hoses you've got bigger problems. If I have a contaminated system I try to use no manifold at all. I just run a hose dedicated to that purpose to the recovery machine.
    I also like 2sac's idea about a separate manifold for systems with dye.
