Results 1 to 11 of 11
Thread: Lennox G20
    have a Lennox G20 unit, pilot and burners fire up with no problem but when thermostat fan switch is set to "auto" the blower will not come on. When set to "on" it seems to work fine any sugguestions as to why this is? Thanks
    SE Michigan
    If your a professional, you should know why.
    "If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
    burlington county n.j.
    need to call for service. i can tell by description what is wrong but not permitted to give diy advise. call a lennox dealer and describe your problem, he should be able to bring part with him.
    Current whereabouts unknown
    never worked on a G20 but I think I heard somewhere about them having problems with fuel filters
    It matters not how strait the gate,
    How charged with punishments the scroll,
    I am the master of my fate:
    I am the captain of my soul.
    -- William Ernest Henley
    also heard of lennox having problems with faulty biconclavicators. Seems the radius rods were shearing right off. May be a factory recall on that part and you could get it fixed for FREE! Ask your dealer.
    Mar 2001
    Early G20's had a standing pilot, if yours is one of those it most likely has some serious rusting in heat exchanger. Later versions were spark ignition pilot. The heat exchanger should be inspected in either case. You should have the unit serviced and repaired by a professional.
    I work for a Lennox dealer, and there's no factory recall on the radius rods, I checked. If the rod has sheered, it can be replaced for only a moderate amount of money.
    they were available both ways from the get go. E in model # told you if it was a sparker.
    as far as the radius rods there was an inspection program but that ended last year.
    Dec 2000
    NW Ohio
    Trick question? Leave the switch in the on position?
    Or try this. Call some one that can get the part and install it. Easy repair if you are a pro. Give them the model # and describe as you did here.
    Mar 2001
    If I remember correctly Lennox dropped the standing pilot model and would supply a electronic ignition conversion kit when a heat exchanger rusted out on one of those. Early in the production run the furnace was available either way, but later the funace was only available with electronic ignition.
    Nov 2005
    Laramie, Wy
    Call a Lennox dealer. Even a poor one should bring that part with them. A good one will also bring the radius rod.
