    Nov 2010
    JCI dmo import issues with NCE
    Hello everyone,
    I 'm replacing an old system (arcnet...) with the new NCM. I am trying to make the new database so i use the import .DMO feature (the site has DX controllers), but i see that the import is not proper. I only can see the AO's and the PMs. I am aware of the feature generate ddl in the GX-9100 program and i made some tests such us deleting PM's or so....
    My question seems easy to answer....
    How can i import the DMO files properly with all the points i need? Do i have to make some changes in the eported .dmo file?
    Thanks in advance
    Mar 2009
    Several Miles from Sane
    NCE or NCM
    NSSF,
    You refered to "NCE" in the title if your post and "NCM" in the description.
    Please clarify which one you have. Totally different procedures for the 2.
    Guessing that you have an NCM since you said "replacing old arcnet" but can't be sure.
    If sense were so common everyone would have it !
    Any advice provided is worth exactly what you paid for it, not a penny more not, a penny less !!
    Nov 2010
    yes sorry you are right its NCE the new one.......
    Yup
    You need to remove any unwanted parameters that you aren't going to use from teh DMO file.
    Here is an example of points which I keep
    * GX9100 Version 7.05 Model DDL Source File for C:\PROJECTS\NAE\SYSTEM91\
    @MODEL+
    CSMODEL "DX9100", "DX9100"
    ******************** GROUP TITLES ********************
    AITITLE "Analog Inputs"
    AOTITLE "Analog Outputs"
    ADTITLE "Analog Data"
    BITITLE "Binary Inputs"
    BOTITLE "Binary Outputs"
    BDTITLE "Binary Data"
    ******************** INPUTS ********************
    * LONGNAME "Disch Air Temperature"
    CSAI "AI1",N,N,"DA-T","Deg C"
    * LONGNAME "Chiller Rm Temperature"
    CSAI "AI2",N,N,"RM-T","Deg C"
    * LONGNAME "Roll Filter Diff Press"
    CSAI "AI3",N,N,"FIL-DPT","pa"
    * LONGNAME "Softner Water Flow"
    CSAI "AI4",N,N,"SOFTFLOW",""
    * LONGNAME "F-4 Lo Speed Status"
    CSBI "DI1",N,N,"F4LS-S","OFF","ON"
    * LONGNAME "F-4 Hi Speed Status"
    CSBI "DI2",N,N,"F4HS-S","OFF","ON"
    * LONGNAME "EF-4 Lo Speed Status"
    CSBI "DI3",N,N,"EF4LS-S","OFF","ON"
    * LONGNAME "EF-4 Hi Speed Status"
    CSBI "DI4",N,N,"EF4HS-S","OFF","ON"
    * LONGNAME "DAT Lo Limit Alarm"
    CSBI "DI5",N,N,"DA-LL","OFF","ON"
    * LONGNAME "Roll Filter End-Of-Roll"
    CSBI "DI6",N,N,"FILEOR-S","OFF","ON"
    * LONGNAME "Chiller Rm Light Switch"
    CSBI "DI7",N,N,"LITE-S","OFF","ON"
    * LONGNAME "Refrigerant Alarm"
    CSBI "DI8",N,N,"REF-ALM","OFF","ON"
    ******************** OUTPUTS ********************
    * LONGNAME "Heating Coil Valve"
    CSAO "OUT1",N,N,"HTG-VLV","%"
    * LONGNAME "Outside Air Damper Cmd"
    CSBO "DO3",N,N,"OAD-C","OFF","ON"
    * LONGNAME "F-4 Lo Speed Command"
    CSBO "DO4",N,N,"F4LS-C","OFF","ON"
    * LONGNAME "F-4 Hi Speed Command"
    CSBO "DO5",N,N,"F4HS-C","OFF","ON"
    * LONGNAME "EF-4 Lo Speed Command"
    CSBO "DO6",N,N,"EF4LS-C","OFF","ON"
    * LONGNAME "EF-4 Hi Speed Command"
    CSBO "DO7",N,N,"EF4HS-C","OFF","ON"
    * LONGNAME "Roll Filter Advance Cmd"
    CSBO "DO8",N,N,"FIL-C","OFF","ON"
    ***************** NETWORK INPUTS ****************
    *************** PROGRAMMABLE MODULES ***************
    * MODULE ACO 1
    CSMODEL "ACO","DX9100"
    CSAD "ACO1",N,N,"DAT-SP","Deg c"
    CSAD "ACO2",N,N,"FIL-SP","pa"
    * MODULE LRS1-32 1
    CSMODEL "LRS1-32","DX9100"
    CSBD "LRS1",N,N,"F4LO-SS","OFF","ON"
    CSBD "LRS2",N,N,"F4LO-CMD","OFF","ON"
    CSBD "LRS3",N,N,"F4HI-SS","OFF","ON"
    CSBD "LRS4",N,N,"F4HI-CMD","OFF","ON"
    CSBD "LRS5",N,N,"OAD-CMD","OFF","ON"
    * MODULE PID 2
    CSMODEL "DAT-PID","DX9100"
    CSAD "PM2K1",N,N,"DAT-LSP","Deg C"
    CSAD "PM2K2",N,N,"DAT-PB","%"
    CSAD "PM2K3",N,N,"DAT-TI","%"
    CSAD "PM2OU1",N,N,"DAT-PID","%"
    CSAD "PM2OU2",N,N,"DAT-WSP","Deg C"
    CSBD "PM2S11",N,N,"DAT-EF","OFF","ON"
    * MODULE COMPRTR 3
    CSMODEL "COMPRTR3","DX9100"
    CSBD "PM3S1",N,N,"FIL-ADV","OFF","ON"
    Nov 2010
    ex: CSBI "DI6",N,N,"DI6","OFF","ON"
    That was the problem my friend. The description DI6 for example must not be the same in both "". I put an underscore in the second bracket and the problem was solved. Thanks for your time.
