Results 1 to 13 of 30
    Jan 2012
    Furnance kicked my rookie butt today
    Guys I need some opinions this am. Working on a Tempstar NUG5075BFA2. It has a VR8204M1075 gas valve. The t-stat calls for heat, inducer goes and closes the pressure switch. They the direct spark ignightor starts sparking and there is a poof of gas that comes from the piliot tube that imd goes out. The gas valve is getting 24v on the red wire and 12v on the black. Do you guys think the valv is bad? This is the first one wire spark ignition system I have seen.
    Quote Originally Posted by Dwarren2012 View Post
    My first suggestion.
    Stop reading voltages to ground when you really want to read across the coil.
    What was the voltage from red to black on the gas valve?
    Jul 2009
    st louis mo
    you need a new furnace, hive me a call, hurry, hurry, theres only a few thousand left
    Mar 2001
    Seattle
    Does anything prove that there is a pilot flame? Thermocouple?
    Dec 2011
    Southern Oklahoma
    Sometimes a puff of pressure then nothing, will happen when the gas is turned off{residual pressure buildup through an almost closed valve or plug left in by gas company}. When something is kicking your butt it's a good idea to start over and never assume even the simple things. You will be surprised how often it's something really simple...good luck
    Jan 2012
    St. Louis Missouri
    Did you clean the pilot tube and pilot?
    Jersey
    Quote Originally Posted by SuperDave89 View Post
    +1 and clean the orfice.
    Ride hard on a Harley!!
    Jan 2012
    St. Louis Missouri
    Right some times its the simplest things!
    Fairfield county Connecticuit
    LP gas or natural what was your gas pressure in out?
    Dec 2011
    bedford ind
    are you using a manometer?
    I dont think he checked the gas pressure prob lp with no gas in the tank LOL
    Dec 2011
    bedford ind
    I've done the same!
    Jul 2009
    Northern area between Alantic and Pacific
    What kind of control board u have? Is it a black box build of Honeywell smart valve? If positive,then check the board first before u condemn the valve. Good luck.
