    Nov 2001
    Warm air going outside from Makeup Air Vent
    Is it normal for warm air to be coming out of the makeup air vent to the outside?
    Massachusetts
    It all depends on the installation. Make-up air can come from many different locations and configurations. It should suffice to know that warm air rises.
    Jun 2010
    Philadelphia PA
    Do you really have an outside, fresh air duct?
    Quote Originally Posted by zakrzep View Post
    If you do and there is a lot of air coming out then you could have leaky return duct located outside the building envelope ( like in an attic) and therefore positive pressure in your home which will then look for a way out.
    The idea that this really is a makeup air vent doesn't sound right
