Page 3 of 3 FirstFirst 123
Results 27 to 31 of 31
  1. #27
    Quote Originally Posted by crackertech
    Really!!! I guess you don't work on a contract Market.
    Some of the new Barker cases, I'm doing them all at once.
    The whole case has to be pulled, you've got to pull the plenum out just to get at the fans.
    Yep, a couple of cheap 9watts make good sense in that case
  2. #28
    California
    This is almost NEVER a good idea.
    There is a proper position for a fan blade within the plenum, and installing a larger (or smaller) sized motor can and WILL change that postition, altering airflow for the worst!
    Replace the motor with the proper sized one.
    X3
    Look here page 2 & 3. Pay attention to wattage and motor dimension.
    http://www.aosmithmotors.com/uploade...Web.pdf?n=5332
    Going higher in wattage will use a thicker motor and place the blade above the plenum. Going lower in wattage will use a thinner motor and place the blade below the plenum.
  3. #29
    Kansas
    Yes JP and it would be a very bad idea for me to disagree with another fellow
    CM that has all those rounds on his profile page
    By all means always take my 45 years of information with a grain of salt as I
    don't mean to criticize others and there are how many grains in those rounds?
    I am so thankful for this forum as it often shows many of us that some of the
    tactics we have used in the past that worked actually turned out to be
    incorrect
    Always go by mfg specs first then if that doesn't work go right to the source
    and ask the mfg application engineer
    They will help you as they are proud of their product and their reputation
  4. #30
    Sep 2011
    Plainfield IL
    Check your superheat too make sure your feeding the evaporator coil properly.
  5. #31
    May 2011
    Spring City, Pennsylvania, United States
    I'm new to markets but in my short experience I would have to agree that this case probably needs to stripped down and cleaned, and possibly even tape off some of the lower louvers to forc
    e.the air north. It's very rinky.dink.but it works.
