    Jan 2012
    Thermostat / Heat Pump Challenge
    Hi,
    I'm a licensed contractor, , Ive installed around 15 Gas packs
    Now I'm installing a package heat pump and running into problems with wiring the thermostat for a york 2.5 ton Heat pump system with Heat Kit
    Ive got it wired up to a honeywell 3000 series thermostat, Using the 2H/1C config.
    Could you guys check my work for the thermostat wiring, Im not getting a response on the heat cycle, fan comes on fine.
    On the thermostat I jumpered E and AUX and connected it to W2 on the unit
    I wired B on the thermostat to C on the unit (per the schematic)
    From the unit to the thermostat G to G , O to O, Y to Y, R to R
    On the thermostat I left L and C open.
    Below are all the pertinent schematics
    so did I cross my wires? What correction do I need to make?
    TIA,
    Warhorse
    The Alamo
    Jumper w1 w2 on the unit and see what happens.
    Read, read, read!
    B on t-stat to C on what unit.
    you're fixing to let the magic smoke out of something
    The Alamo
    Quote Originally Posted by dandyme View Post
    Good one.
    I am so used to Trane's C being B.....
    LOL!
    Read, read, read!
    Jan 2012
    C on what unit?
    On the heat pumps terminals
    Heat pump = Unit
    I'd like to keep the magic smoke inside there please.
    jumper w1 and w2
    will this work?
    B on stat to C on unit is dead short when you call for heat.
    I would agree that jumping W1 to W2 will get your electric heat on.
