Thread: co-ray-vac
    Jan 2012
    co-ray-vac
    Hello i have an older co ray vac low intensity tube heat system that I have been working on. It has 2 Linier burners on the branches. (4"tube) One I can't get the main burners to lite, only the pilot. my vac is between 4 and 4.5 " on the end with ristrictor plate in place. Gas pressure is ok. If i jumper out the flame switch the main burners kick on. I have replaced the mercury flame sensor with no luck. The tip of the flame switch glows red looking at it from the sight glass in the burner tube. I have made sure that the connections are good going from the switch to the main valve. I have cleaned the pilot and sparkplug orffices through the burner. it has a new air filter. I have nothing to go off of as far as btu's model number goes. the tags are nowhere to be found. Everyone i have talked to about this just tells me to give my customer co-ray-vacs number to schedule a service call with them. whitch as much as it shames me todo so I am willing to except defiet. but not until Ive tried everything i can. Any thoughts?
    Ontario Canada
    Welcome EH!
    Best I can tell you is, Call a pro... You can learn from them.
    Never give up; Never surrender!
    If you go to roberts gordon webite you are look at some specs on the co ray vac. I have installed 2 of these and they are a nice system. How is the Filter that clean and been replaced lately?
    http://www.rg-inc.com/CoRayVac-infra...ing-system.htm
    http://www.rg-inc.com/pdf/Manuals/10...%20Rev%20L.pdf
    http://www.rg-inc.com/vacuum-pump.htm
    If you can not do it right, Why even do it at all?
    Jan 2012
    Thanks for the input. Customer decided to replace the system with a positive pressure set up.
    Quote Originally Posted by bubbaj View Post
    Not sure what state you are from but i really like the VANTAGE ® MODULATING Infrared Heater made by roberts gordon just like the system you have now. Glad to hear you have some work ahead of ya always a good thing!
