Page 1 of 6 123456 LastLast
Results 1 to 13 of 67
    Connecticut
    Chiller Plant Optimization
    Does anybody know where I can get information about optimization strategies for a chiller plant? Thanks in advance.
    San Diego, CA
    Connecticut
    Thanks Digo!
    Dec 2006
    What? Who? Where?
    Tridium based solution:
    http://optimumenergyco.com/
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Open protocols? You can't handle open protocols!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
    Jan 2002
    Fort Worth\Dallas, Texas
    Good luck finding something affordable if you are looking for a packaged solution. I have looked at optimum. Building Logix also has a Tridium solution.
    I am currently trying to implement this myself on a project with AX if anyone has done this before. Im not just talking about the condenser reset either, that is easy. I am talking more along the lines of the Hartman Loop.
    Go Rangers!
    Aug 2009
    Jurupa Valley, CA
    Quote Originally Posted by The Reaper View Post
    Something to think about is that there is a LOT of variables in a chiller plant. To truly optimize the whole plant, you must know how all those variables will affect the system. (Things like Chiller efficiency over it's load range, and how this changes with condenser water temperature. The electrical use for the Cooling Tower fans over their range, etc).
  7. Likes oldhweller liked this post
  8. #7
    Jan 2002
    Exactly!
    Go Rangers!
  9. #8
    San Diego, CA
    This paper from Mr Hartman himself tells a bit more about one of the methodologies (Variable primary flow):
    http://www.hartmanco.com/pdf/p04.pdf
    There's even a code snippet with some if/then/else statements in there. I'd like to see an actual sequence of operation for a Hartman Loop.
  10. #9
    Jan 2002
    Yes, I would too Digo.
    Go Rangers!
  11. #10
    Jun 2010
    New Orleans
    I'm trying out the CPO10 in CCT on one of our smaller plants, it reads to be promising as far as retrofit of older equipment.
  12. #11
    Jan 2002
    What is that Joe?
    Go Rangers!
  13. #12
    Jun 2010
    New Orleans
    Johnson controls as a pseudo plant optimization program in CCT
    pdf with regarding it
  14. #13
    Connecticut
    Thanks for the replies. The main problem I see is this particular building has 3 300 ton York Screw machines. All of the sequences call for an aggressive condenser water reset but anything below 78 degrees F is no good on these chillers.
