    Jan 2012
    Brentwood, TN.
    Managing Heat In Split-Level with Terrible Install
    We are renting a split-level house while we are building. The HVAC system in this house has got to be the worst install ever. There are three levels: basement, first floor, and second floor. The basement and second floor are controlled by one thermostat that is located on the second floor right at the top of a wide stairwell that comes up from the first floor. The thermostat on the first floor is set at 68F, and it seems to work well and is accurate. The second floor thermostat is also set at 68F, but reads between 71F and 73F because of rising heat from the first floor. We have hung a heavy quilt at the base of the steps from the first floor to the second floor and this has helped tremendously in dropping the reading on the second floor thermostat. We have gotten it to a point where it is giving an accurate reading that is truly being realized in the rooms on the second floor. The problem I am having is that when second floor thermostat kicks the heat on, it is also heating the basement, which we never use and don't intend to use. There is one return air vent in the basement and one at the top of the stairs on the second floor. In order to conserve energy and increase air volume on the second floor, would it behoove us at all to block or partially block the return air vent or the registers in the basement? I do not have the ability to damper the trunk that feeds the basement and the second floor. We would be okay if the basement was 0F if the second floor was comfortable, and also if that would save us money in not having to heat the basement.
    Thanks in advance for any help.
    Fort Worth, TX
    Heating the basement helps toward keeping your first floor more comfortable, via not allowing the floor of the first level to get too cold (assuming there's no insulation between the first floor and the basement, of course). I agree, by your description, the configuration of your system is not ideal.
    Since you're building a new house, take any lessons you derive from the HVAC in this house, and ensure they are not repeated in your new place.
    - Homer Simpson
    Jan 2012
    Brentwood, TN.
    Quote Originally Posted by Shophound View Post
    Thank you, ShopHound. Being a split-level house, the first floor is not any way directly above the basement. The master bedroom on the second floor is above the basement, and the two guest bedrooms on the second floor are above the basement and garage (which is attached to the basement). Your advice seems to be sound, and I will follow such. As for the new build, I have already sought the advice of professionals in this forum as to the design of such. We were very attentive to select an HVAC installer who knew what he was doing and could accommodate our desires to have an efficient and comfortable house. We are learning a lot through this process. Thanks!
