Results 1 to 13 of 14
    Jan 2012
    two wires for programmable thermostat?
    Hello,
    I bought a house in March '11. It has dual zone heating running off baseboard (AC is run through vents off the upstairs programmable thermostat). The downstairs zone is an old thermostat that I was hoping to replace with a programmable. When I pulled it off the wall it had two wires attached. I went to Home Depot and the sales person said a programmable only works if there's three wires. My friend, an electrician, said that's not true and two wires would suffice. I've tried researching the web to no avail. I was hoping someone here would be able to help?
    Your help is greatly appreciated in advance!
    Edit: not sure if this should go in here, please move accordingly.
    Jan 2012
    programmable thermostats, duplicate thead
    Duplicate post - apologies
    Suarez,
    Please don't start multiple threads on the same topic.
    Massachusetts
    For heat only, 2 wires will work fine, read the instructions and make sure power to the unit is off, if you have problems, call your electrician friend.
    Jan 2012
    Thank you, sir. Seems HD employees got it wrong yet again...
    Nice rifle in the avatar. Not a .50 cal, right?
    Duplicate threads are not permitted. Please don't make duplicate threads, thank you.
    Mount Airy, MD
    Dang it Jim ! you beat me to it
    Quote Originally Posted by Chris_Worthington View Post
    You were reading that long winded thread, that is ready or ARP.
    Massachusetts
    Quote Originally Posted by Suarez7 View Post
    M14, 7.62mm
    Jan 2012
    Quote Originally Posted by mlstark View Post
    M14, 7.62mm
    ...should've recognized from Call of Duty. Thanks again
    @Mods - Sorry for the duplicate posts.
    Charleston, SC
    Any digital thermostat, programmable or not, that is unit powered will need 3 wires unless it is a "power-robing" thermostat. A battery operated thermostat, programmable or not, can use the 2 wires.
    "Customer Service" is not a department, it's an attitude!
    Apr 2010
    Minnesota
    Use a Honeywell pro6000, battery powered.
    Oct 2008
    East Texas
    Quote Originally Posted by cartercrew View Post
    There is no way a 2 wire system can be power robbing... it has to have at least 3 wires to use one curcuit that is not powered to complete the ground. It will have to use a battery operated stat or run a new set of conductors.
