Results 14 to 20 of 20
    Jan 2011
    Where do you drain a condensing furnace? No sump pit, no floor drains?
    Jul 2002
    Chariton, Iowa
    Quote Originally Posted by jimmyed View Post
    Well, if you use a condensate pump, anywhere you want I suppose.
    To get the degree symbol on Windows hold down the Alt key and type 0176 or 248 on the keyboard number pad. It is also available via the character map, and on Windows 8.1 devices with a touchscreen via the on screen keyboard.
    There is no "E" in either BluVac or Blu-ray Disc.
    If you are the type where the painting is more important than the frame, or you just like movies, join me in listening to the widescreen.org podcast.
    Jan 2011
    Anywhere? Being the sewer right?
    Jul 2010
    georgia
    well, at least with the condensate pump there would have been a check valve.
    doesnt prevent gas issues but at least prevents backflow.
    Jul 2010
    georgia
    get a dishwasher tailpiece and drain it into a sink trap.
    Feb 2012
    From what I've been taught you are not supposed to tie into any plumbing whatsoever....and if your run is going to be too long they make small pumps for that.
    I used to pump septic tanks for a living and have seen animals cause this exact problem....they crawl down the vent pipe on top of your house and get stuck...I was always told to wrap your vent pipe in chicken wire to stop this from happening.
    Apr 2001
    Over Here
    Revenge of the squirrel
    Quote Originally Posted by AStudent View Post
    This was exactly what happened. It was self-induced though.... The homeowner was at war with the squirrels eating out of his birdfeeder and chewing through the soffit, getting into the attic.
    Homeowner shot him with a pellet gun, and the squirrel ended up crawling down the stack and kicked the bucket, plugging the section that the AC drain was tied into. The result was a memorable incident for many, with Mr. Squirrel definitely having the last word.
