Results 1 to 13 of 65
06-17-2011, 07:41 PM #1
- Jan 2010
- Lower mainland bc.
- 105
Can geothermal heat be stored in the earth?
This is a interesting question I think, some one asked once but lost the thread. Can radiant heat from heat panels on the roof be stored underground, then retrieved to heat for example the house, or hot water?
Thanks a bunch!
06-18-2011, 08:53 PM #2
- Aug 2006
- 2,444
Trane was experimenting with something similiar in the mid 1970s. They were heating a slury that was similiar to concrete, that would never set. I believe the stuff also had a lot of salt in it. The problem was it had to be mixed to distribute the heat evenly, that used almost or more energy than was captured. Don't think they ever found something that had a large BTU storage ability, in a compact size, that didn't have to be mixed.
Horizontal Ground Source heat pumps loops do that to some extent.
06-19-2011, 02:17 AM #3
- Jun 2011
- Virginia Beach VA
- 28
You could store some heat in the ground but the losses will be very high. Better to store the heat in water in a well insulated tank. If it needs to be underground, it is possible to have below grade insulated hot water storage. Lots of people heat their home with solar radiant (hydronic) systems, do you have an unusual situation?
07-11-2011, 08:46 AM #4
- Aug 2007
- ky
- 181
Drake's Landing Canada
http://www.dlsc.ca/borehole.htm
a solar thermal energy earth storage community
07-11-2011, 09:37 AM #5
- Jan 2010
- 105
All I can say is WOW
Did you guys read the last paragraph of this document??
I know, if a medium takes a long time to heat to its maximum heat absobtion potential, it can also take a long time to give off heat. But this last paragraph is interesting. Takes three years to reach maximum heat absorption yet, will give off enough energy after the third year, to heat a house for a entire winter.
I do not know what is the take on this, but I bet physics minded people would like to know.
I wonder what the cost would be to put something like this in?
07-12-2011, 01:48 AM #6
- Aug 2007
- ky
- 181
the system is actually has two storage parts. one using Tank filled with glycol mix. another the bore hole fields.
The solar collector has enough capacity to heat up the house and the first storage tanks. but since the bore hole field is vast it act just like giant heat sink. for the first 3 years
the bore hole field capacity is probably in the order of 100x of the first storage tanks
11-02-2011, 07:16 PM #7
it alreadys happens...via the sun.
if you want more heat transfer, you dont need more heat, you need something that transfers heat better than high density polyethylene.... see www.advgeo.com
11-02-2011, 09:03 PM #8
- Aug 2006
- 2,444
I wonder what they do where the ground is acidity, like here in Maryland where it can eat up a "L" pipe in five years. Also how do they protect the system from lightening, and transcents, we've had holes blown in under ground copper pipe at work!
11-02-2011, 09:57 PM #9
Professional Member*
- Feb 2006
- Float'N Vally, MS
- 1,622
11-02-2011, 10:20 PM #10
- Sep 2005
- North GA
- 17,675
I think I would stick with the water loop... Water (or water/glycol mix) in some kind of plastic or vinyl/plastic or special tubing... probably would last a lot longer than CO directly in contact with the earth.
Someone correct me if I am wrong: A WF system installed by a special contractor (with the proper WF certs) can have a 50 (yes fifty) year warranty on the horiz loop??? That in itself would be worth a lot of the high cost of the install.
Also... I heard WF may be bringing out an inverter drive compressor Geo system sometime in 2012... anyone know anything more about this? Reason I ask is I may be looking at a GEO system in 2014.GA-HVAC-Tech
2 Chronicles 7:14
11-03-2011, 08:05 AM #11
11-03-2011, 08:06 AM #12
11-03-2011, 11:28 AM #13
- Sep 2005
- North GA
- 17,675
Down here in GA... CO water lines from the street to houses rot after 20-30 years... and no... it is not from the inside out. Folks NEVER replace with CO anymore... always with PVC or some miracle pipe.
BTW: WHO warrants the loop? The warranty is only as good as the co offering it. As I understand it... WF is the one that warrants the loop... (please correct me if I am wrong). Gotta remember: A local contractor may not be there next year... or when he retires... or when his son takes over and chooses to change the name and not honor previous warranties.
IMO: one should always be wary of warranties... rather use old fashioned common sense about them.GA-HVAC-Tech
2 Chronicles 7:14
