Page 1 of 4 1234 LastLast
Results 1 to 13 of 42
Thread: R22/410A
    Mar 2006
    South Jersey
    Hmm
    I am considering 3 HVAC replacement systems, AS, Carrier and Trane. One (AS) has a R22 a/c unit and two (Carrier & Trane) have 410a a/c units. The refrigerant and suctions lines are imbedded in the wall and ceiling (it's a condo unit) and can not be changed. The Carrier and Trane guy have told me they will flush the lines thoroughly before using the 410a and the AS guy recommends staying with R22.
    Any opinions on using 410a in existing, older lines?? Possible mechanical risks?? Would flushing the lines remove all of the old residue??
    Thanks,
    Vince D.
    I don't know
    The problem is oil incompatibility - have you ever completely removed oil from a surface in one go?
    Not a technician - wait for other responses
    To be honest with you vinced, the flush is called RX-11, and I have not heard any horror stories just yet about it causing any problems. Then again, 410 is pretty new in the residential market and problems could arise after a couple of heating and cooling seasons with the equipment.
    R22 units will be manufactured until 2010, after that manufacturers will not be able to produce units made with R22. R22 completely will be out of production in the year 2020. People like DuPont will not be able to manufacture R22 after 2020.
    Now knowing all this information, what I would do is go back with R22. Let me explain why: The average heating and cooling system will last you maybe anywhere between 12 - 15 years. Some longer, some shorter. By the time you will need to replace it again, it will be right around the time R22 will be phased out of production. Hopefully within those 14 years, you will be moved out of that place and into a house where you don't have to worry about the lineset not being replaced. I hate to say it, but go back with R22 and let the future homeowner worry about converting over to R410. If there was a way to change the lineset then I would say to convert to R410, but I am a little sceptical about the RX-11 flush and if it is not done right then you will have a mess on your hands. Just my thoughts on the subject.
    Mar 2006
    Tampa,FL.
    Thanks,
    Vince D.
    I would stay with R-22 there is going to be a replacement refrigerant for it and you can change over to that freon after 2010 R-12 has been replaced with 134A freon.
    Maryland's Eastern Shore
    There is no retrofit drop in refrigerant for HCFC-22 and as far as I know, none in research. To cross your fingers and hope that someone develops it is a waste of time. I have used RX-11 flush and it does a sufficient job to warrant using the lineset for HFC-410a. HFC-410a does have different operating pressures, is hygroscopic compared to HCFC-22, and operates with a different oil, but not much else is different. To make an informed decision, you really need to know that while HCFC-22 is being phased out just like all the HCFC's and the CFC refrigerants before it, HFC-410a is just a stop gap, it satisfies the requirement of zero ozone depletion, but it still has a global warming potential, and it has a questionable history of reliability due to installer ignorance. People don't like change, and HVAC techs REALLY don't like change. If it were my condo and I was going to be there for the next 20 years, HFC-410a would be my choice, probably with Carrier. If I were going to sell it in 5 years, I'd probably still choose HFC-410a, if I was selling it next year, then I would go with HCFC-22.
    Just my two cents.
    Mar 2006
    South Jersey
    It seems like Carrier has a better handle on the 410a situation than the other HVAC manufacturers. I do agree that "change" (in any profession) gets people a little nervous. We all like to stick to what we are comfortable with.
    Thanks for your input and advice!!
    Vince D.
    Nov 2005
    Brownbakistan
    Just my two cents.
    There are HFC refrigerants to replace R-22 in any application. (NU-22 from ICOR is one) You will not have a problem with availability of refrigerant for a system you buy today.
    [Edited by tostaos on 03-24-2006 at 08:22 AM]
    Nov 2005
    Brownbakistan
    Manufacturers do not recommend reusing of R-22 line sets. Why spend all the money and have a system that will probably not last as long as it should?
    Mar 2006
    South Jersey
    Tost,
    Let me get this straight. There is already a replacement for R22 on the market?? Manufacturers "suggest or recommend" that older R22 lines not be reused with 410A??
    Vince D.
    http://www.410a.com
    To read the myths.
    Carrier has no problem using the old lineset IF they are the correct sizes.
    PS We have installed hundreds of Puron systems with the old line sets.
    [Edited by dash on 03-25-2006 at 04:11 AM]
    Nov 2005
    Brownbakistan
    I am not an opponent of R-410a at all, but the promoters of the site of the link in the last post could tell you some myths as well.
    Dash is correct, they have no problem to reuse the line set, but they do not recommend it either.
    http://www.icorinternational.com/nu22-opening.html
    R-417a has a 10% lower capacity than R-22 but higher efficiency.
    R-422a for medium and low temperature has an improved cooling capacity and energy efficiency compared to R-22.
    The pro of R-410a is that the compressors should last longer than their R-22 counterparts, when the system is correctly installed.
    Recommendation ? Depends on who you ask.
    Mar 2006
    Tampa,FL.
    Just my two cents.
    You guys better start stocking up on R-22 in case there is no replacement for it there is a lot of equipment that uses R-22 and buy it while it is here and avalible i have allready bought 3 jugs of it and plan to buy more.
