Results 1 to 11 of 11
    Jul 2005
    Phoenix, AZ
    Confused ASHRAE Humidity Standards
    Does anyone know if the ASHRAE manuals have the standards for humidity control for apartment multifamily complexes? Could someone direct me in the right direction?
    Jan 2012
    http://www.ashrae.org/technology/page/336
    This lists ASHRAE 55 (humidity level should be below 65% RH... duh) and ASHRAE 62.2 concerning ventilation. Does that answer your question?
    Jul 2005
    Phoenix, AZ
    Thumbs up ASHRAE Manuals
    Thanks for the help. I was looking for the standards number. Judt wanted to get something in writing.
    20% - 60%
    May 2008
    brooklyn ny
    THE ONLY WAY IS CHECK ASHRAE WEBSITE FOR THAT INFO GEOGLE IT
    Jul 2011
    East coast USA
    Quote Originally Posted by phxhvac View Post
    http://epb.lbl.gov/publications/lbnl-54331.pdf
    Have fun, this might help. but don't get to caught up in the standards they can be daunting to make sense out of them.
    Oct 2009
    Murfreesboro, TN
    Are you asking if maintaining a humidity level below 65% will prevent mold growing on walls, etc.? Please don't give the owner a false sense of security. There can be leaks around windows, under sinks, under outside sliding doors, and around bad roof flashing that can keep a surface or wall wet enough to grow a patch of fungus. The interior humidity level can still be under 65% rh during all of this. If a food source stays wet for an extended period you will have a fungi family form.
    Madison, WI/Cape Coral, FL
    Unfortunately, mold grows when any surface approaches saturation. Cool surfaces will be musty with 65%RH. An example is a carpet on a concrete slab. With cool slab, the %RH between the slab and carpet approach 100%RH. The result is a musty odor that indicates mold growth. Also dust mites grow with +60^RH.
    <50%RH assures mold and dust mite are controlled in most homes. During winter weather <35%RH may be required to avoid condensation on the cold surface of the exterior surfaces. This is not stated in ASHRAE standards.
    Regards TB
    Apr 2012
    Millsboro, DE
    PHX: You want ASHRAE 55, the Standard for human comfort. ASHRAE 62 covers air quality.
    May 2008
    Cebu City, Philippines
    Use Ducted FCU, measure %RH coming out. If beyond control, say %60+. Process air through pre-cooling, so that from %60+ it would reduce to %50 or less.
    regards,
    moriel
    Jun 2002
    Dacula, GA
    Quote Originally Posted by drk View Post
    20% - 60%
    20% is too low. Don't let it drop below 30% to prevent static shock especially when walking across carpet and touching a door handle. 65% is the max you should ever have. Mold growth takes off above there. Thank you very much
    Sen. Barry Goldwater
