    Aug 2013
    variable speed systems "required" for spray foam homes???
    I received a call today from an HVAC contractor who stated a foam contractor told their customer that a variable speed HP should have been installed in their home because it has an encapsulated attic.
    The problem being experienced is quite simply NO MAKEUP AIR which is causing a fireplace to backdraft.
    The foam contractor obviously is placing blame, even with no HVAC this problem would exist; but I still would like to hear if anyone has EVER read that foam homes require variable speed systems? And where can I find any such documentation?
    It's got nothing to do with the type of blower motor, its got everything to do with adequate make up air.
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by Tloganm View Post
    Well insulated air tight homes need aggressive make-up air ventilation to purge indoor pollutants and renew oxygen. Any open combustion appliance is capable of being backdrafted by more powerful exhaust devices like a kitchen hood or clothes drier.
    Homes in green grass climates with adequate fresh air ventilation and occupants that add moisture need supplemental dehumidification to maintain <50%RH during low/no cooling loads and +55^F outdoor dew points.
    Using a whole house dehumidifier with the fresh make-up air ventilation option is ideal way to purge indoor pollutants, renew oxygen, and maintain <50%RH with a simple high efficiency a/c. Units like the site sponsor, Ultra-Aire whole house dehumidifier are designed for these situations.
    Regards TB
