Results 1 to 11 of 11
    TEXAS
    No pride in their craft :(
    Not specifically a HVAC WOS, but worthy of a welder WOS.
    This weekend I had to replace some of my pipe fencing due to a car that decided to leave the highway. Luckily for the driver, the bird that flew over the pipe and ***t on it, didn't do a very good "welding" job. I used a standard 6010 rod that isn't known for looks but thought mine came out a little better than the previous attempt.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	weld comparison.jpg
ID:	236221   Click image for larger version.
Name:	weld comparison 1.jpg
    Avatar is a tribute to my Great Grandfather, Andrew Stewart. This pin was one of his advertisements for his heating and plumbing business. I never knew him but must of inherited his love of things mechanical since I am the only blue collar worker in the family
    Nice job
    Your work
    Theirs...
    But unto the wicked God saith, What hast thou to do to declare my statutes, or that thou shouldest take my covenant in thy mouth? seeing thou hatest instruction, and castest my words behind thee.---Psalm 50:16-17
    Ontario Canada
    Nice Job.
    Never give up; Never surrender!
    Dec 2011
    North Texas
    Nice job.
    TEXAS
    Thanks for the kudos. House was owner-contracted to the lowest possible bidder for all the trades, but the price was right. It had two Goodman units, both WOS installs. Attic unit replaced with an AS dual fuel 15 SEER and the downstairs closet unit replaced by a ClimateMaster split.
    First three photos are the goodman closet install. Its hard to see in the photo but the B vent is touching the door trim and the entire run was nearly 30' horizontal. Installers did not have any clue how to install a sheet metal plenum with slip and drive clips. They taped the coil onto the furnace and put a couple of token sheet metal screws in the front and a liberal use of tape.
    Last photo is the nearly finished CM install. Just need to insulate the supply ducts and cap the existing propane line.
    As long as there are hacks out there installing crap like this it keeps me busy!
Name:	furnace in closet.jpg
ID:	236281   Click image for larger version.
ID:	236291   Click image for larger version.
ID:	236301   Click image for larger version.
Name:	CM in closet nearly complete.jpg
    Apr 2008
    Alberta Canada
    I love how you just slap that old furnace on his floor without drop sheets. Professionalism is more than a good install=)
    Do it right the first time.
    TEXAS
    Quote Originally Posted by 21degrees View Post
    It is my floor, it's tile and after the unit was installed it was replaced with wood to match the rest of the downstairs area.
    Jan 2012
    Tallahassee,Fl
    Nice clean job sir.
    Arizona
    Quote Originally Posted by texas cooler View Post
    It looks like you have some zoning going on there, nice job!
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Oct 2010
    we call that beaver,good job with a 6010!
