Results 1 to 10 of 10
    flex hose for oil?
    Found this at my uncle's house (I only do refrigeration). Is this a listed connector for oil?
    Massachusetts
    There are flex lines made specifically for oil, I use them on boilers that have swing doors, and when installing a tiger loop. Read the tag that's on the line, it will tell you whether It's rated for oil, or for plumbing.
    Quote Originally Posted by CoolWine View Post
    They do make flex oil lines that look like this but without reading the rating on the white tag it is hard to say.
    Vancouver, U.S.A.
    that looks like one of the oil flex lines. I would have personally put the shut off at the coupler between the hose and copper line.
    Air conditioning to all and to all a good night
    May 2011
    ct
    flex line
    hard to tell form the pic,but it most likely is rated for oil.it looks like a buderus which is a swing door boiler.wish more installers did that.
    Thanks, I'll check the tag. It just threw me when I saw it never having seen it used before.
    New Mexico
    I thought codes required a connector and lines that wouldn't fail in a fire.
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
    Massachusetts
    Quote Originally Posted by hvacker View Post
    I thought codes required a connector and lines that wouldnt fail in a fire.
    Braided oil lines are approved here in MA, but we also have to have a firomatic at the burner and at the tank.
    Fairfield county Connecticuit
    yes they come with Buderus boilers
    Oct 2008
    Royal Palm Beach, FL
    Those are legal oil connections in Massachusetts.
    I don't know as I would leave it so you could trip over it. I would have clamped the envirotube to the floor and put a loopy thing in the hose.
