Geothermal Purge pump cart
2 years old works great. $2500 obo Also I will include pipe fustian kit for $500 obo
The Purge Pro is a geothermal purging system designed specifically for residential applications. The Purge Pro provides the installer the ability to flush and purge debris and air from geothermal systems to ensure optimal operation. It can be easily mounted to a two wheel cart for ultimate maneuverability. The two horse power motor provides all the pumping power needed to purge most residential and small commercial systems - and conveniently operates from 120V. A cone shaped screen filter provides water filtration and air dispersion. Quick connect hoses promote simple set up and operation. For more info on this product go to http://www.geothermalsupply.com/prod...ails.cgi?id=10
Please put your email address in your profile, not in post, thank you.
