had one one time installers installed txv didn't take out the flow rater, low suction poor split unit was charged by subcooling to specs
Printable View
Yes i removed flow rater.
sounds like you got a bad evap coil form the factory and its restricted
get your post up and get your pro membership and post this on the pro side
You need to know subcool and superheat. Your subcool should be higher than 3. Sounds undercharged. What was the superheat?
Orifice clogged from install?
Any filter dryers that could be pluged?
Negative points for
http://i776.photobucket.com/albums/y...ecromancy4.jpg
:angel:
jim
only half of coil getting cold? 3 degree SC? not sure what spilt is... If its milk, you aint supposed to cry. I know that. I've heard old timers call the temp difference the "split". If thats what you're talking bout, 10 just wont do. I'm probably wrong but I'm thinking under charged.
get your subcooling up to 10 and see what happens.
It sounds like you're undercharged.
