AOP Contractor Locator Map
HVAC-Talk Ask Our Pro's features an interactive global map to further assist equipment owners to locate a qualified HVAC service company in your area. It's called the AOP Contractor Locator Map.
The AOP Contractor Locator Map incorporates the popular GoogleMaps functionality along with a customized, interactive user interface which allows you to select an HVAC-Talk AOP Service Company near you to help you with anything HVAC.
Access The AOP Contractor Locator Map:
To access the map, simply click on the following link:
<center>
</center>
(To return to this page, click on this link http://icemeister.net/images/aopmap_snuffyredirect.png in the upper RH corner of the map page or the back arrow on your browser.)
How to Use The AOP Map:
First, if you're not familiar with using GoogleMaps, here are few helpful hints:
The map first appears showing the US and Canada with all available AOP Contractor Markers visible.
SAMPLE
<center><a href="http://icemeister.net/images/aopmap_shot1.png" target="_blank"> <img src="http://icemeister.net/images/aopmap_shot1.png" alt="aopmap_shot1" width="750" height="480"/> </a>
</center>
Map Navigation:
You can navigate around the map in several different ways.
- Using the navigation tool in the upper left corner, click the up/down/right/left arrows to pan in any direction.
- Click on the center box (inside the directional arrows) to reset or recenter the map at any time.
- Move the slider bar up to zoom in or down to zoom out.
- Use the up/down arrows at the top and bottom of the slider to zoom in or out.
Zoom To Your Location:
This is the Zoom To Your Location Tool. Enter your street, city and zip/postal code in the left box. The more complete your address is, the closer the map will zoom in to your location.
<center><a href="http://icemeister.net/images/aopmap_addresszoom.png" target="_blank"> <img src="http://icemeister.net/images/aopmap_addresszoom.png" alt="aopmap_addresszoom" width="560" height="98"/> </a></center>
Then click on the box to the right, and the map will take you to your location as shown here.
<center><a href="http://icemeister.net/images/aopmap_locationzoom.png" target="_blank"> <img src="http://icemeister.net/images/aopmap_locationzoom.png" alt="aopmap_locationzoom" width="750" height="480"/> </a></center>
AOP Pro * Member locations with approximately 50 miles of your location will be displayed. To view a Member's information, click on the map marker and an InfoWindow will pop up.
There you will be able to click on links to telephone, fax, email or website. Also, there will be a list of the types of services the member offers along with any additional information.
Get Directions:
If you need directions to the Member's location, click on the link for Directions "From Here" and enter your location. A new map will appear with written directions and a suggested travel route will be indicated.
The AOP Markers:
The map markers indicate the locations of our HVAC-Talk Pro *AOP Members.
They are divided up into four groups as denoted by the marker colors:
<center><a href="http://icemeister.net/images/aopmap_markerlegend.png" target="_blank"> <img src="http://icemeister.net/images/aopmap_markerlegend.png" alt="aopmap_markerlegend" width="618" height="97"/> </a></center>
AOP Pro * Member List
At the bottom of the map page, you’ll see a scroll-down listing of all AOP Pro * Members. Use your mouse scroll wheel or drag the slider to scroll the listings. Click on a name to go directly to its map location.
<center><a href="http://icemeister.net/images/aopmap_memberlist.png" target="_blank"> <img src="http://icemeister.net/images/aopmap_memberlist.png" alt="aopmap_memberlist" width="409" height="115"/> </a></center>
We Are Growing Fast:
Please note that the AOP Contractor Locator Map is not static or complete by any means. We’re adding new AOP Pro * Member locations every month, so if you don’t find one near you, please check back soon.
