Thank you all very much =)
I want to thank you all for your help.
Here is my model number of my air handler and outdoor unit:
Goodman units inside and outside
Inside: ARUF 032-00A-1B
Outside: CPLJ30-1B
Is there a way I can post a picture of my installation? Since I have a horizontal install I am concerned about these baffles being repositioned etc as posted by beachwalker, The only thing that I see inside is the A coil sitting on its side with a pan below it as I think the unit was designed this way..
I will cap the opening that is before the trap and see where that goes.. The line is definately not clogged and the evaporator is clean as a whistle.. The drain pan is not cracked but I cannot otherwise pinpoint why the water is on the insulation and between the insulation and the outer cabinet walls but maybe after I cap this opening this will stop.. How would I dry this insulation up? I thought about runnig the heat but that would be crazy since it is summertime.. I am going to set the unit off the concrete blocks and put it on plastic feet like the ones that the outdoor unit sits on and make darn sure it is level and I will put a sheet of plastic under the unit since its just above the dirt. Instead of a dehumidifier could I put a supply vent down there and basically make it a conditioned space?
Again I thank you all for your advice and suggestions.
Have a great day!
Chad
