How do you know what kind of solder it was?
Some solders result in a stronger connection than the 15% you mention.
PHM
Quote:
Originally Posted by
crbn79
I just had an office body spaz out about the cost of 15% silver rods that I order. She could not understand why I can't use the 0% @ $30 vs the 15% @ $210. After a lovely debate about how I've had to repair nearly 50 leaking braze jobs in the last 4 weeks and an estimate of costs involved with labor I think she finally got the picture!
I thought I have seen it all until I found a braze job done today with plumbers solder!
so how do you know that the solder you saw was plumbing solder?
How do you know that what you saw wasn't refrigeration solder?
PHM
crbn79
Such as the plumbing solder? I'll use a 5% or 0% when I can on an R-22 system if there's no danger to overheating valves etc. But sometimes the potential collateral damage warrants the 15%.
On a side note, I've been trying a few sticks of 0% from a vendor rep that flows very well at lower heat. I don't recall the name of it but if it holds up I will definitely use more often.
