Can someone tell me if ACR copper pipe is refered to by the I.D or the O.D. I hear conflicting answers depending on which supply house I go to.I was told Air conditioning pipe is measured by th O.D and plumbers use I.D.
Printable View
O.D.
AC&R Copper Tubing is measured by O.D., Plumbing Copper Tubing is measured by I.D. and is cheaper due to its not being dehydrated or charged to prevent contamination.
http://www.coppercanada.ca/pdfs/28e.pdf
This explains it in better detail
[Edited by retired btc on 03-23-2005 at 02:57 AM]
Thank you very much!
That will finally put that to rest!
Micky, don't rest yet, here's some more info.
AC&R copper pipe and tubing are measured by Outside Diameter.
Plumbing copper tubing is measured by Outside Diameter also.
Plumbing copper pipe is measured by Inside Diameter.
Talking about copper tubing, does any know where to purchase metric copper tubing and fittings? I’m looking for some 10mm OD and 6mm OD stuff.
Crimp and braze... lolQuote:
http://www.grainger.com ?
Seems like they carry just about everything else, maybe they'll have something.
