Electrician Needed~~~~~~~~~Licensed
Guess what it is not his responsibility to wire the (2) pole 30 amp breaker. It's yours,call an electrician and have them wire from the main panel to the air handler #8 THHN wire. Then be sure that you have (2) stage thermostat to bring on the stripe when needed, other wise they will time on and you will have 19.5@amps on each strip at call for heat by (1) stage..I they are stage properly they will increase the amount of heat you feel when the unit is calling for second stage.
<<<<<<<<<Aircooled>>>>>>>>>>>>
