Quote:
Originally posted by titan7
Thanks Dash, those are great suggestions.
I will not be able to drop the ceiling in the Bath as it's only about about 7' high now. it's only 5 wide by 9feet long, toilet and sink, with a exshast fan in the middle of the ceiling.
On the 14" the soonest an 18" could be fitted is in the attic just as it comes out of the framing.
With regard to the hole on the platform, the hole is the same size as the intake of the furnace. We were going to use the smaller filter rack at first so they told me to cut out the hole to the Furnace specs. During the install the smaller honeywell rack did not fit right so they went with the larger 20x25" rack.
I the entire furnace,coil etc would need to be disconnected and removed for that option.?????
If we are doing that I would also have the entire platform redesigned.
What about running another supply to the opposite side of the wall where the 9" is going in. I was thinking could be run externally in on the ceiling of the garage and to the right of the furnace and going through the wall above the washer and dryer? On the inside wall it would look like the duct above my wine frig only 10 feet to the left? If if was return it would have to enter the platform from the side(cut through the drywall) I am not sure that would be to code.
