CO2 plus any moisture in system equals carbonic acid. Carbonic acid is very corrosive and will do nasty things to anything metal in the system.:eek: Dry nitrogen only, could also use argon but nitrogen is much cheaper
Printable View
Hey, if you really want to screw up your system ... jus read and do everything in the Doolin's Trouble Shooters Bible. Then use some dytel for leak detection and some thaw-zone for the moisture yoru gonna have from all the co2 you've been infecting the systems with.
:D
Seriously though..... this it the type of stuff that diferentiates the hacks from the tradesmen.
