Originally Posted by
jal
I have a Carrier Performance system and the Aux is on a LOT. Example: the other morning it was on about every 10 min. in one hour's time. It was a cold morning (about 39 degrees). The other night it was on when the outside temp was 60. It does not seem right that the Aux is on so much. I understand the defrost may cause the aux to run, however, on and off every ten minutes and on and off when the OAT is in the 40's, 50's, 60's seems like a lot. T-stat was changed out and is still a Carrier stat. Any ideas? Was told that the Carrier stat is used because it is an 8 wire. Would really appreciate any thoughts.
