HI i AM TRYING TO FIGURE OUT IF THIS TERMINATION KIT GOES TO AFIREPLACE HAS ANYONE SEEN PIPE LIKE THIS BEFORE,THANK YOU
Printable View
Looks like sidewall termination cap and pipe for a gas direct vent fireplace.
Yes --- but it isn't prudent to use whatever kind of venting material that comes to hand when installing a direct vent fireplace.
Rather commonly, direct vent fireplaces need to use the specific vent that they are designed to use or they wont work properly and can be a hazard.
Quite often there is little tolerance on such systems. Install them correctly and they will probably work fine. Miss on some detail and they may work poorly or even be a hazard.
