would this thermostat be appropriate or too complicated for a heat pump as below
Honeywell VisionPro 8000 TH8321U1006 Thermostat
carrair air handler mod #fv4bnf03
unit #38eyg036300 hard time reading numbers
thank you in advance
Dial the # on the back of it. Thats all the help you can get here till you turn Pro.
Your other post, don't indicate that you are in the HVAC industry.
You said your a draftsman in one of them.
Are you DIY, or do you have a bad contractor that doesn't answer your questions.
The TH8321 is a good stat for most any heat pump. Depends on teh application though.
Go here for a demo of the tstat in question:
http://www.hotfreshcool.com/visionpro_demo.html
