I am trying to find out any information on an old Command Aire Water source heat pump that I can. Any help would be appreciated.
Model # SPHD101911H10BC310100000020
Anyone have any suggestions?
Printable View
Trane bought the Command Aire line. Call 254-299-6300 for info.
Thanks, I will try that.
I have some old command-aire units from 1985 still new in their original boxes.
model # SWP 354EA. They are vertical units.
does anyone have nomenclature information? i.e. SWPH 107 or SWPH 254. Trying to figure out nominal capacity.
I have some spec info sheets on SWPR 261 thru 611 water source heatpumps. typically the 261 indiates capacity:
261 = 24000 btu
281 = 30k
361= 36k
411 = 42k
511=49k
611= 62k btu
some info here:
http://www.waterfurnace.ca/Engineer/...cification.pdf
http://www.waterfurnace.ca/Engineer/...Command%20AIRE
I have a command aire model # swpr 351gss that needs replacing or parts to repair.(leaking condenser coil ) is the 354ea about the same product? and how much you asking for them. thanks
I am trying to find out any information on an old Command Aire heat pump # SWPV 301. Any help would be appreciated.
