Central Air Novice---questions within
1st off, my basement unit stopped blowing cold air last night. Having some experience with a window unit I checked the filter. Filter was clogged and the Condenser(?) was iced up on both sides and not allowing air to flow through, probably caused by the dirty filter right? Size is 16"X20"X1". What is a good filter replacement? This looked like it was constructed of a weaved fiberglass. I know here at work we have a pleated(?) filter.
Also, I noticed that cool air was leaking out small little holes in and around the unit....should those be sealed up with tape?
The upstairs unit is in the attick. I checked the filter there and it looked clean but the size is 16"X25"X1" and it was crushed to fit. I measured the opening and the 16" wide was more like 15" 13/16's of an inch. Should this be rounded down to say a 15.75" Filter?
Sorry for the newb questions but this is my first experience with Central Air systems.
There are pleated filters that aren't that restrictive
Quote:
Originally Posted by
mrgto
Ryan, thanks for the respons. Yea, they are just small holes/gaps in the sheet metal of the unit.
No idea when it was last changed. We moved into the house in April and it was there. There is only one filter in the basement. In the attick there are three but the on in the unit was crushed to fit and the other two replacements certainly were not the correct size for the unit.
So a Blue or pleated are best? I did shut off the unit to let it thaw overnight. I plan on stopping off to day on my way home to get some filters. I'm thinking I go a tad smaller than the filters currently installed.
Beenthere told me that if the pleats have a sharp angle from the apex to the bottom of the pleat, its too restrictive. I'd look at Lowe's, HD for filters. Also, one of the guys on here suggested looking into Nordic Air (12 MERV) very good. Mine fills up fast so its imperative to change it every month.
I'll put up w/a bit of restrictiveness, to keep crap off the blower wheel and coils and from blowing back into the house. That's just me.
