Do I Need A Whole House Dehumidifier?
During the summertime, the humidity levels in my house run between 48 to 54% with 50% being the average. The HVAC company which installed my AC unit says these humidity levels are too high and recommended that I install a whole house dehumidifier.
What would be an optimal humidity level in my home during the summer? Wouldn't a thermostat with a humidity/dehumidity control on it do the job for a lot less money? I live in central Massachusetts. My house is 2100 sq. ft. and I have a 3.5 ton AC unit/coil on my furnace (with floor registers). Thanks!
Tushai Beenthere... hadn't thought of that...it is exht.
Quote:
Originally Posted by
beenthere
The fresh air may be causing some of your trouble. Depends if they installed the OD sensor or not.
Do you know how many CFM it is bring in.
Not all new homes are as tight as people thing.
Your design conditions are below my area. Unless you have a lot of glass, and no shade, your most likely over sized.
Sounds like your A/C was sized by rule of thumb using 650 sq ft to the ton, and then rounded up.
If you don't have a VS blowr in your furnace. The IAQ isn't going to do you any good as far as humidity control.
During your hottest days, does it run constant to maintain temp, or does it cycle on and off.
With an oversized A/C, and no VS blower, you will most likely need a whole house dehumidifier. Wspecially with that fresh air intake.
Also, the Aprilaire 8126 is just a motorized damper and control.
if its hooked into the supply. It isn't bringing in fresh air, its exhausting air.
Its suppose to be hooked into the return duct.
I put a ton of these in (8126) and had not thought about the results of being on the supply... it will exhaust.... your good
How do you spell Tushai ?????
