Thanks for the correction. I should have made that finer point.
Yes, the mineral oil in R-22 is not compatible. After a flush you would be testing for the presence of mineral oil.
Printable View
You don't have to do that either.
POE oli has been used in refrigeration long before it was used in A/C.
The same end of the world if the oil is mixed saying was going around.
Turned out, its not completely true.
A small amount of MO can be mixed with POE, no harm done.
Intentionally letting MO in the system will give you troubles. MO doesn't mix well with R410A. So it doesn't travel with it like oil should.
Yes I do and your attitude is not necessary. I never said I dont WANT to spend the money. I said I DONT HAVE the money to spend and I was simply asking if there were any possible solutions that could better the situation without requiring the complete replacement of the entire system at a cost of $5-7k.
Basically as I have asked before is, if I replace the old air handler with a similar SEER rated and same brand unit as the compressor unit would it make any difference? A new air handler is a hell of a lot cheaper than a whole new system. I asked this question in hopes to get a straight forward answer from a group of individuals who know what the heck they are talking about as opposed to the lackeys I have dealt with from local HVAC companies here in Phoenix.
Yes I know if I replace the entire system with a 2.5 ton 19UL Trane model that my house will be colder than a penguins butt on a winter day. However I just do not have the money to implement such a solution.
