I agree. GM had problems in the past (before the 90's) with ceramic compressor seals as well.
Printable View
i am a certified gm tech (do ac and electricla) i read this thread and am
amused/confused . all of you say leave repairs you are not qualified for
to a proffesional.we are not lining our pockets we are just making a
living. we do not set the labor rates and our pay rate is a fraction of that
rate which has widened over the years . also buying and bringing your
own parts .ive seen a thread in another section of this forum and from
most replies i dont guess you guys are real keen on us buying from
internet and asking you to install. i am having a complete system done in my
home and am leaving it to a qualified dealer .i dont want to work on my hvac
system when i get home i just want to turn it on. i also made a post asking
opinions on my install choice and this question has generated more response
than my home heat pump question. by the way if you buy a gm compressor
from a gm dealer and a gm tech installs it,compressor is covered by a
lifetime warranty as is water pump,starter alternator.
This is the only good I see from having a dealer do it is that it's covered under warranty. Since I fix machines for a living, I'm a DIY type of person, because it's a hobby of mine, so I'd do any repairs myself that I can.
I have had 4 head gasket failures on my 2.2L Sonoma and I brought it to the best/biggest dealer in town. $125.00 an hour? Techs get what, $20 an hour? $1300.00 later it's fixed. The gasket blew again after 12 months, and they repaired it under warranty. Then it blew again later and I had a local mechanic fix it for $700.00. Same warranty.
I think this fix at a big GM dealer would cost at least $1000.00. I called about the compressor and they wanted $523.00 for the kit. :eek:
I wanted a pin for the rear tire mount and it was $31.00, and $18.00 for the bushing each, which I need 4. GM parts seem REALLY expensive.
GM parts cost nothing compared to............
MOPAR!!!!!!
I need a part for my dodge, I gotta sell my first born and re-finance the house to do it.
i did exactly that: bought a compressor off ebay and gave it to my mechanic to install and vacuum the system. then i installed the refrigerant myself. after i removed the fitting, the shreader valve got stuck! so i just put the cap back on and am praying. its not leaking but eventually i will need to evacuate and repair the valve.
one point: ask for the old compressor back as you an sell it to a jobber as a core
