At least this pole shows a good thing, over 90% of pro's here are using micron gauges.
Printable View
How many of you guys put on a filter drier when you seal up the system?
Seen a lot of guys pulldown to a good vacuum but no filter..
Attitude was if it needed one the factory would have provided one.
I never heard of a micron guage until 410a. use it every time because i no longer will install r-22.
we mandate that every time a system is open a new filter dryer is installed.
And that ok Buddy we all started somewhere unlike some here that will make you feel so bad and belittle folks because they were born with a micron gauge in there butt and a NATE certificate in there hand and a Sling Psychrometer in there teeth. Rather than putting folks down here that haven't used these few tools of the trade we "Pro's" should be encouraging old and new Pro's that haven't been using these tools how these tools can be beneficial to them in servicing a/c equipment. I guess instead of the sarcasm and put downs use our knowledge and experience and treat these folks as students and teach them as any good teacher should, remember none here knows it all anyway, but if we all work "together" we can all gain knowledge from one another, "maybe" even something we did not know, just my two cents. ;)
Whole new thread. But you're right, 410 will MANDATE micron guages usage.
And holding a neagative press for leak detection will become problamatic.
410A driers are so much more hygroscoic you stand to contaminate the drier if you have a leak with the systeem under vacuum.
I think that $400 Robinaire micron tester is for me.
