Originally Posted by
dbg305
You answered me accurately in your first post and asked the appropriate questions. I do not understand the change of tune in your attitude toward me.
#1 is NOT about the lines being exposed, I already admitted that was my error, what more do you want
#2 I didn't ask them to cover them, or you if they should be covered, someone else mentioned that
#3 do you always leave wires exposed where a child could handle the connections that are 10 ft from an inground from swimming pool? I don't believe that is up to code, if it is, there is definitely a problem in the legislation that covers HVAC inspections. This oversight or whatever it is only proves that they did not take the care they should have in the entire installation.
To answer your question about what would make me happy, I want the lines in the furnace room run again so that there is no chance they will be damaged when routine regular maintenance is done right under them. This will happen one way or another. My understanding of copper pipes is that they are soft and bend and kink very easily, however the copper pipes used in an A/C installation may be of a harder copper than water pipes are.
