Originally Posted by
bmathews
You can install the new condenser (outside) with the older air handler (inside) and it will work to some degree. You won't be getting the full efficiency, but it will cool. It is preferable to put in a matched system, but if you don't have the money, you don't have the money, what can you do? I wouldn't consider replacing just the compressor. It's too old to waste your money. It will be close to replacing the entire condenser in cost and the warranty will be 1 year. The only way anybody will know about the conditions of the setup for the warranty is if your contractor "rats" you out. Nobody will come out to inspect the setup from Ruud. If he will do that, then dump his arse, he's a POS. I would do as much as you can afford right now, save up and finish it within a reasonable amount of time and you should be fine.
