Hello all,
I hope everyones Tuesday is going well. I too am looking for a copy of the WINCIS or Datamate. I will be running it on WINXP and just need a tool to change some duplicate addresses on a couple of trunks.
Thank you.
Printable View
Hello all,
Thank you.
Hi everyone,
I am also looking for a copy of the old Datamate Base. Can anyone help?
Scott
email is
thanks for any help.
Hi everybody
I just install the TEC Unit Vent Controller P/N 540-509, unfortunately the TEC can't communicate with BMS
Here data collected from the field.
The TEC on the field configured as follows:
DO8 as START/STOP
DI2 as AIRFLOW STATUS
DI4 terminal no. 21-22 JUMPERED
AO2 as MOTORIZED VALVE MOTOR
With this configuration, which application used?
How can I program the TEC?
Software to monitoring the TEC is INSIGHT ver 3.1
On the monitor displayed point details as follows:
Point Name : CA1L
Point Type : LD0
Descriptor : C AHU1 LT LG
Can I program the TEC using INSIGHT?
But I can't find any menu used for programming
Current Information
Value :ON
Status :FAILED
Priority :NONE
Total :.......hours
Physical Address
DO : 00511150
Please send me copy of software to program the TEC
Do this physical address indicate the address that should be programmed?
Hoping you help, thank you
What is the work around for a laptop that does not have a native serial port for CIS20?
Does anyone know? I got a new laptop and they don't offer one with a serial port. So everytime I try to use CIS it gives me an error. Any Ideas?
I'd love a copy of Datamate or CIS if anyone has them. I know this is an old post, but thank you! If I get them I will post them on Download.com so anyone can find them.
Anybody has the copy of datamate or CIS software? It is badly needed.
Felix C.
[QUOTE=felcus;7554902]Thank you very much, can you send it now? below is corrected email
Regards
Felix C.
QUOTE]
Still isn't working friend. I even tried to send from another email account. Still getting a delivery failure :(
