Did you swap over the SECURITY key for your copy of SIGNAL from the old computer ?
Printable View
"Did you swap over the SECURITY key for your copy of SIGNAL from the old computer ? "
I've found removing the text file is easier.
Good for you
ok found some bulletin info , it was a cable from printer that was conflicting system, have it all up now. is there any "newer" software - front end- that would run this gcm 8000 system or is signal it for this older product?. also if the costumer wanted to replace this system with something newer, what are my options so that it stays open for us to work on and service, we not anybodys authorized dealer or factory trained representative...and also retain as much of the existing hardware/controllers as possible.
need your email to send the manual
to a DOS based computer.
Have XPSI, MZ but no documentation. Any manuals for trouble shooting, programming BC would be awesome. Shows all site as "Empty" and "Disconnected".
Any help would be really appreciated.
Check your email I sent you some stuff.
hey guys i m new here n i really need literature on MZII n GCM
any pdf related to this will be appreciated
thanx
my email: Email Address Removed
I am in need of the Micronet software. I need to look into a Micronet program for integration reasons.
