Nordyne already has micro channel a coils in their air handlers.
Carrier went to all aluminum micro channel on com and industrial equipment. Didn't go very well. They have discontinued for now. It is going that way across the board though. They just got to work out the kinks. Heatcraft has also gone to the micro channel on cond coils and seem to be holding up better then carrier's version.
I was talking comm. ref. here...
We have put in several MC inside and out Nordyne units. No problems yet....
Only thing we had was a Nordyne coil replacement last year. They gave us a MC replacement on a HP. Replaced by the book even changed the bi-flow, vacc. Etc. in the end of the cool season. Three months later the piston/strainer in the CU was plugged.
The coil had something in it.
I took a tour of the Trane Factory in Clarksville, TN last year. Not only will the coils be all micro channel, an engineer there told me that the refrigerant lines will eventually be as well. Its a matter of economics. Cost of aluminum vs the cost of copper.
Post removed for advertising.
You can't advertise your business unless you are a Professional Member.
There are some Commercial Air Conditioning systems out there which are starting to use Aluminum Tubing as opposed to Copper Tubing.
